ScreenAlignment
ScreenAlignment
Enum Controls the alignment, given by Elipse E3 Viewer, of all Screens that do not specify a value different from default. Possible values for this property are the following:
1 - paTopLeft: Adjusts the Screen to the top left corner relative to the visible area. It corresponds to the Force Top/Left option of a Screen's Alignment (This Screen) contextual menu, at run time
2 - paCenter: Adjusts the Screen to the center relative to the visible area. It corresponds to the Force Center option of a Screen's Alignment (This Screen) contextual menu, at run time
The next figure shows an Elipse E3 Viewer's contextual menu at run time, with the respective configuration options of this property.
Options for Elipse E3 Viewer's ScreenAlignment property at run time
