WriteValueMode |
Read-and-write property controlling the behavior of sending a value in writing operations. This property must be configured according to the OPC UA Server used, or the writing fails. Possible values for this property are 0 - wvmDefault: Follows the default behavior, that is, the behavior configured in the OPC UA Driver to which this OPC UA Block Tag belongs, 1 - wvmValueOnly: Writes only the value, or 2 - wvmValueQualityTimestamp: Always sends the quality and timestamp together with the value.
