Size |
Defines the size of an OPC UA Block Tag's set of values. Please check the documentation of the Driver used to verify the limit for this property, according to B1 to B4 parameters. By creating the OPC UA Block Elements for this OPC UA Block Tag, users can access all values read and also allows writing values to a device. Default value of this property is 0 (zero).
