Quality |
This property informs the quality of the value in the Value property. Each time an OPC UA Driver attributes a new value to this OPC UA Block Tag, it also configures the quality of that data. This is a read-only property. Default value of this property is 0 (zero, bad quality).
NOTE |
For more information about quality, please check topic Quality on Elipse E3 User's Manual. |
