AllowRead |
Configure this property to define whether this OPC UA Block Tag must be read or not by an OPC UA Driver. If this property is set to True, then the OPC UA Driver automatically updates the OPC UA Block Element's Value and Bits, from Bit00 to Bit31, properties in time spans. Otherwise, this OPC UA Block Tag is not read if this property is set to False. Default value of this property is True.
