EUHigh |
Defines the maximum value to set to the Value property, adjusting the scale to the value of a device before this attribution. Likewise, at the moment of the writing the inverse operation is performed before sending the value to the Driver. This conversion only occurs when the EnableScaling property is set to True. Default value of this property is 1,000.
NOTE |
Bit values, the Bit00 to Bit31 properties, are not affected by scale adjustments, that is, they represent the bits of a value read from a device before conversion. |
