AllowWrite |
Defines whether this OPC UA Tag must be written or not automatically when the Value, any Bits, from Bit00 to Bit31, or RawValue properties change. If this property is set to True, these changes are sent to the device linked to the OPC UA Subscription. Otherwise, changes are ignored. Default value of this property is True.
