AllowRead |
Defines whether this OPC UA Tag must be read or not by an OPC UA Subscription. If this property is set to True, the OPC UA Subscription automatically updates the Value, Bits, from Bit00 to Bit31, and RawValue properties of this object in time spans. Otherwise, this OPC UA Tag is not read. This property cannot be changed while this object is active. Default value of this property is True.
