<< Click to Display Table of Contents >> RemoveRow |
RemoveRow(Row)
Removes a Row at a specified index. The Row parameter determines the table Row to remove and it must be a value between 1 (one) and Count. The next script contains an example of using this method.
Sub RemoveRow_Click()
On Error Resume Next
Dim Bind
Set Bind =_
Screen.Item("Rectangle1").Links.Item("ForegroundColor")
If Bind Is Nothing Then
MsgBox "Rectangle1 has no link."
Else
MsgBox "Rectangle1 is linked to '" & Bind.Source & "'"
Dim row
row = Screen.Item("Row").Value
MsgBox "Removing line " & row
Bind.RemoveRow row
End If
