ReportFailure
ReportFailure
ReportFailure(FailureName, FailureDescription, FailureWeight)
This method allows an application to report failures to a Server, which can be viewed by right-clicking Elipse E3's icon on Windows Notification Area. When this method is used, Elipse E3's icon on Windows Notification Area starts blinking in red, indicating that a failure occurred. Reported failures are usually conditions preventing an application from working partially, such as problems with communication on a serial port, inactive network link, or database without connection, and that usually cannot be detected by a Server. This method can be used to warn a system operator about problems in a server and also to help the automatic Hot-Standby manager to decide which server is more suitable to execute an application.
NOTE
This method is only available in the Server.
This method contains the parameters described on the next table.
Parameters of the ReportFailure method
Name
Description
FailureName
Contains the name of a user-defined failure. This parameter must be passed to the ClearFailure method when an application detects that this failure is no longer active, such as "FaultCOM1"
FailureDescription
Textual description of a user-defined failure, such as "Communication failure at COM1"
FailureWeight
Defines a failure's severity or weight. A value of 0 (zero) indicates a warning without severity. Values greater than 0 (zero) indicate failures. The greater the value, the severer the failure
The next script contains an example of using this method.
Sub TagSerialStatus_OnValueChanged()
  If Value Then
    ' The tag value is True, application is on error
    Application.ReportFailure "FAULT_COM1", _
      "Communication fault at COM1 port", 100
  Else
    ' The tag value is False, clears the failure
    Application.ClearFailure "FAULT_COM1"
  End If
