BackgroundStyle
BackgroundStyle
Enum Determines the background style of Ellipse, Rectangle, and Rounded Rectangle objects. The available options for this property are described on the next table.
Available options for the BackgroundStyle property
Option
Description
0 - rv2BackSolid
Solid background style, uses the color indicated in the BackColor property
1 - rv2Gradient
Gradient background style, from the color indicated in the BackColor property to the color indicated in the BackColor2 property
2 - rv2Pattern
Pattern background style, with background in the color indicated in the BackColor2 property and lines in the color indicated in the BackColor property
