GetExportFilter |
GetExportFilter(FilterName)
Returns an object specifying custom export parameters for a Report. This method contains a FilterName parameter, which indicate a type of format for exporting. The available options for the FilterName parameter are the following:
•PDF: Exports data to PDF (Portable Document Format) format
•Excel: Exports data to Excel's spreadsheet format
•HTML: Exports data to HTML (Hyper Text Markup Language) format
•TEXT: Exports data to Text format
•RTF: Exports data to RTF (Rich Text Format) format
•TIFF: Exports data to TIFF (Tag Image File Format) format
After retrieving a filter, all properties described on the next table can be modified.
Available properties on an export filter
Filter |
Description |
AutoRowHeight |
Excel |
In True (default), automatically configures a row's height. In False,configures size to the largest element on a row |
BorderSpace |
Excel |
Minimum space between cells. Default value is 59 twips |
CreateCSSFile |
HTML |
If True, generates a CSS file on the directory indicated by HTMLOutputPath |
DoubleBoundaries |
Excel |
In True, indicates that elements aligned to the right must replace the ones aligned to the left on the same column. Otherwise, leave it in False to free more space |
ExportRange |
HTML |
Indicates a range of pages for exporting, such as "1, 2, 3-9, 14" |
FaxExport |
TIFF |
Object that allows exporting data in RFC 1314 TIFF format |
FileName |
All |
Informs the name of a file to which data is exported |
GenPageBreaks |
HTML |
In True, places page breaks under the lowest element in each Report's page |
HTMLOutputPath |
HTML |
Default path for HTML files |
JPGQuality |
Indicates the quality level of exported images, between 0 (zero) and 100 |
MinColumnWidth |
Excel |
Minimum size of a column. Default value is 1011 twips |
MinRowHeight |
Excel |
Minimum size of a row |
MultiSheet |
Excel |
In True, each Report page goes to a separate spreadsheet |
PageDelimiter |
Text |
Configures or returns a delimiter character between pages |
SuppressEmptyLines |
Text |
Removes or inserts empty lines, for layout purposes |
TextDelimiter |
HTML |
Configures or returns a delimiter character between texts |
TrimEmptySpace |
Excel |
In True, the vertical space between elements is removed. Default is False |
Unicode |
Text |
Determines whether text is saved in Unicode format (16 bits) or not |
WebCacheOutput |
HTML |
In True, a Report is exported to the WebCache service. Otherwise (default), it is not exported |
