ItemID |
This property determines the path that identifies the OPC Tag on the OPC Server to which the OPC Driver connects. Definition of this path is flexible and depends on the specific OPC Server. Usually, OPC Servers specify an ID space with hierarchical items, such as ParentItem.ChildItem.Tag1. This property works as a unique key for data, considering where or what allows an OPC Server to connect to a data source. Although its default value is an empty String, users must specify a value for this OPC Tag to be valid.
