Bit00 to Bit31 |
These properties represent all 32 bits of an OPC Tag's Value property, where Bit00 is the least significant bit and Bit31 is the most significant bit. Modify each one of these bits implies in changing OPC Tag's Value property and vice versa, but this only happens when the UseBitFields property is set to True. Default value of these properties is False.
NOTE |
Bit values, the Bit00 to Bit31 properties, are not affected by adjustments in the scale, that is, they represent the bits of the value read from a device before conversion. |
