Alignment |
This property specifies an object's position, relative to its legend. Available options for this property are 0 - fmAlignmentLeft: Aligns the legend to object's left side or 1 - fmAligmentRight: aligns the legend to object's right side (default). This property cannot be changed while this object is active.
