BackStyle
BackStyle
Enum This property defines a style for an object's background. Available options for this property are 0 - fmBackStyleTransparent: Defines this object as transparent, that is, no object background is drawn or 1 - fmBackStyleOpaque: Defines this object as opaque, that is, its background is drawn (default).
NOTE
This property does no affect bitmap's transparency. Users must use an image editor such as Paintbrush, for example, to save a transparent bitmap. Not all ActiveX objects support transparent bitmaps.
