<< Click to Display Table of Contents >> SetValueData |
SetValueData(ValueName, TemplateName, Data)
Changes the value referring to a Template defined for a certain Set of Values. This method contains the ValueName parameter, which is the name of a Set of Values, TemplateName, which determines the name of a Template, and Data, which is a value to set to that Set of Values. This method performs a check for limits and returns True if that operation is successful or False otherwise.
NOTE |
For more information about this method, please check articles Working with Formulas in Elipse E3, Creating a Value Set at Run Time, and Changing a Value Set at Run Time on Elipse Knowledgebase. |
