DataSourceSize |
Indicates the maximum size of Unit fields on the Database table. Default value of this property is 200 and its value must be positive.
NOTES |
•This property's data type is a 32-bit integer, but it depends on the data type defined by the database server used (Access, SQL Server, or Oracle). •Change this property to a value less than the previously configured may result in truncating data already stored on the Database table. |
