CreateFile
CreateFile
CreateFile(ProjectName, ClassName, [FileName], [FolderName], [RunWizard], [OpenView])
Creates a new object on a project file (.prj). Parameters for this method are the following:
ProjectName: The name of the project file to insert the object. This parameter cannot be empty, and the project file must be loaded in Elipse E3 Studio. It can be a project file's full path or a Domain file's relative path. There is no need to add a .prj extension
ClassName: The name of the object's class to create. Please check the next table for possible values for this parameter
FileName: The name of the inserted object. If this parameter is omitted, then it uses a default name to create an object of the type indicated by ClassName. The maximum allowed size for this parameter is 32 characters, and if it already exists, it is automatically incremented
FolderName: The name of the Folder to create the object. If this parameter is omitted, the object is then created at project file's root. The Folder name must obey the same rules of Note's section of the RenameFolder method
RunWizard: A Boolean indicating whether the configuration wizard of the class indicated by ClassName is opened after executing this method. If this parameter is omitted, the configuration wizard is opened
OpenView: A Boolean indicating whether the View of the inserted object is opened after executing this method. If this parameter is omitted, object's View is opened
Possible values for the ClassName parameter
Object to create
Parameter value
Alarm Configuration
DB.AlarmConfig
Alarm Server
DB.AlarmServer
Database
DB.DBServer
Data Server
Panel.DataServer
Formula
DB.Formula
FrameSet
Panel.FrameSet
Historic
DB.Hist
I/O Driver
IODrv.IODriver
OPC Driver
IODrv.OPCDriver
OPC UA Driver
IODrv.UaDriver
Report
Panel.Report
Screen
Panel.Screen
Storage
DB.Historian
Viewer
Panel.Viewer
