AddStorageTag |
AddStorageTag(Name, FieldType)
Adds a Tag from the Storage to the Query. The Name parameter receives the name of the Tag to add. The FieldType parameter indicates this Tag's type (0: Double, 1: Bit, 2: String, 3: Integer). Returns a Boolean indicating whether this operation was successful or not.
NOTE |
This method fails if the QueryType property is configured to 0 - qtDBServer. |
