SourceTypeName |
SourceTypeName(SourceType)
Returns a String with a description of the active Measurement Source, that is, the ActiveSource property of Analog Measurement and Discrete Measurement objects in Elipse Power. This method is available in Links, as well as in scripts. Possible values for SourceType parameter are:
•-1: Empty String
•0: Active Source
•1: SCADA
•2: Operator
•3: Control Center
•4: Billing
•5: Calculated
•6: Database
•100: Topology Processor
•101: Power Flow
•102: State Estimator
•103: Load Shedding
•104: Distribution Load Modelling
•105: Self-Healing
•106: External Reader
NOTE |
In case the value passed on SourceType parameter is not one of the possible values, this method returns a String "???". |
