Minimum |
Determines the minimum Tag value. Default value is 0. The next script contains an example of using this property.
Sub CommandButton2_Click()
' When clicking the button, a message box is opened,
' indicating DemoTag6 Minimum property value
MsgBox Application.GetObject("Data.DemoTag6").Minimum
