<< Click to Display Table of Contents >> SrcHiValue |
This property specifies the highest value reached by the source. The next script contains an example of using this property.
Sub SrcHiValue_ValueChange()
On Error Resume Next
Dim Bind
Set Bind = Screen.Item("ScrollBar1").Links.Item("Value")
Screen.Item("ScrollBar2").Max = Value
If Bind Is Nothing Then
MsgBox "ScrollBar1 has no link."
Else
MsgBox "ScrollBar1 is linked to " & Bind.Source & "'"
MsgBox "Changing SrcHiValue from " &_
Bind.SrcHiValue & " to " & Value
Bind.SrcHiValue = Value
End If
