OnError
OnError
OnError(Number, Description, SCode, Source, HelpFile, HelpContext, CancelDisplay)
Triggered by a Report's internal error. If this event is not handled, Elipse E3 then displays a generic error message.
Parameters of an OnError event
Name
Description
Number
Integer identifying this error
Description
String with this error's description
SCode
Integer with OLE subsystem's error code (not used)
Source
String with the object that generated this error
HelpFile
String with the name and path of a help file
HelpContext
Integer of help topic's context referring to this error
CancelDisplay
Boolean indicating whether this error must be displayed on a message box
