OnRead |
OnRead()
Occurs when an OPC UA Tag's value is received from an OPC UA Server. Use this event to perform an operation right after data is modified in the OPC UA Tag object, in the Bit00 to Bit31, Quality, RawValue, TimeStamp, or Value properties.
