<< Click to Display Table of Contents >> Validate |
Validate(Cancel, NewValue)
Occurs after testing SetPoint limits (please check MinLimit, MaxLimit, and EnableLimits properties) and before sending a SetPoint value to a Tag. The purpose of this event is allowing users to cancel sending SetPoint's value to a Tag.
The Cancel parameter is a Boolean that indicates if attributing a SetPoint's value to a Tag must be canceled (Cancel equal to True). Default is False, that is, SetPoint's value is sent to a Tag. NewValue is the evaluated value. The old value can be accessed in SetPoint's Value property. The next script contains an example of using this event.
Sub Text1_Validate(Cancel, NewValue)
' Displays a MessageBox that asks a user
' if the new SetPoint value should be used
message = "Current value: " & value & vbnewline & _
"New value: " & NewValue & vbnewline & vbnewline & _
"Do you accept the new value?"
If MsgBox (message, vbQuestion + vbYesNo, _
"Validate Event") = vbNo Then
Cancel = True
End If
