<< Click to Display Table of Contents >> MouseIcon |
This property sets an image to the mouse pointer whenever it moves over an object. This property is valid only when the MousePointer property is defined as 99 - fmMousePointerCustom.
An image file can be selected to use as a mouse pointer by using the Properties List (.cur or .ico extensions) or via scripts, by using the LoadPicture method to specify a file path and name containing a customized icon (.cur extension only), according to the next example.
Sub CommandButton1_Click()
' Setting the 99 - fmMousePointerCustom item to this property
' so that it accepts mouse icon customization
Screen.Item("CheckBox1").MousePointer = 99
Screen.Item("CheckBox1").MouseIcon = LoadPicture("c:\a.cur")
