SimpleAreaFilter |
When this property is set to True, the behavior of filtering by Alarm Area names is based only on the coincidence of the initial part of a name. When this property is set to False, this behavior considers the entire Area name, but allows using wildcard characters and multiple Area Filters, which must be separated by colons. Please check also the AreaFilter property, which specifies a Filter by Area name.
