Define a Compression Level |
Users can enable compression of communication packets using REC between E3 Server, Elipse E3 Viewer, and Elipse E3 Studio, by using the Compression level item.
Default value for this item is 0 (zero). If this item is not modified, the system automatically assumes that compression is disabled.
If this item is modified, any value between one and nine enables compression. Recommended value is 6 (six). Any values outside this range disable REC packet compression.
This configuration is applied only for compression of an E3 Server or an Elipse E3 Viewer executing on a local computer. E3 Server, as well as Elipse E3 Viewer, support packet decompression, regardless of their configurations.
