Enable Script Debugger
This option enables or disables declaring the hierarchy of scripts for Elipse E3 processes. Default value of this option is No (disabled). The available items in this option are described on the next table.
Items available in the Enable script debugger option
Option
Description
Enable script debugger for E3Run
Enables or disables the script debugger for the E3Run process
Enable script debugger for Studio
Enables or disables the script debugger for the E3Studio process
Enable script debugger for Viewer
Enables or disables the script debugger for the E3Viewer process
NOTE
The default value for the options described on the previous table is the value defined in the Enable script debugger option.
