Define an Interval Between Process Statistics
This section allows configuring time options for recording process statistics. Available options in this section are described on the next table.
Options for interval between process statistics
Module
Description
E3Admin
Configures an interval between E3 Admin's process statistics. Default value of this option is 60
E3DBEngine
Configures an interval between E3DBEngine's process statistics. Default value of this option is 60
E3IoServer
Configures an interval between E3IoServer's process statistics. Default value of this option is 300
E3OpcClient
Configures an interval between E3OpcClient's process statistics. Default value of this option is 60
E3Run
Configures an interval between E3Run's process statistics. Default value of this option is 60
E3Server
Configures an interval between E3Server's process statistics. Default value of this option is 60
E3Studio
Configures an interval between E3Studio's process statistics. Default value of this option is 60
E3UaClient
Configures an interval between E3UaClient's process statistics. Default value of this option is 60
E3Viewer
Configures an interval between E3Viewer's process statistics. Default value of this option is 60
NOTE
For all modules, a value of 0 (zero) disables statistical recording. Using a value between one and nine forces Elipse E3 to use a value of 10. All values are in seconds.
