<< Click to Display Table of Contents >> Define an Interval Between REC's Statistical Log |
This options allows configuring the frequency, in seconds, of REC protocol statistics' log recording. Default value of this option is 300, or five minutes. A value of 0 (zero) disables periodic log generation, and the minimum accepted value is 10. In case of typing a value between one and nine in this field, Elipse E3 then uses the value 10.
