Acess via Script
Acess via Script
To use AppBrowser from a script, open a script View and click AppBrowser on the toolbar of the Scripts tab. In this mode, objects are separated as shown on the next figure.
AppBrowser via scripts
The left panel contains the following items:
The first item, displayed isolated, is the Context. A context object is the one originating the call to AppBrowser, that is, the script's owner
The next item is the full Hierarchy to reach a context object, if this context is not in project's root. This object can be expanded and the context object itself can be seen in this hierarchy
If the context is not a server object, the third item displayed is the Viewer (the Application object)
The Server item lists all server objects belonging to an application. If this item is the current context, it contains an indication of Application
The Tasks item displays the most common tasks to execute via scripts. These are Open Screen, whose result is an expression to open the selected Screen and it is equivalent to the Open Screen Pick, and Load Report, whose result is an expression to load a Report. This item can be displayed or not, depending on whether there are Reports or Screens on the project
The VBScript item displays all functions from the VBScript language available for use in scripts
The E3Globals item displays methods for global usage in Elipse E3
According to the selected object, the center panel shows its properties and methods.
