OPC UA Driver
OPC UA Driver
An OPC UA Driver communicates with an OPC UA Server that implements historical and real-time readings, such as EPM. This object can be used as a data source for a Query object. To insert an OPC UA Driver in a project, right-click this project's name in Explorer mode and select the Insert - OPC UA Driver option. In Domain mode, right-click the Server objects - Drivers and OPC item, select the Insert OPC UA Driver In option and then a project's name.
Inserting an OPC UA Driver in Domain mode
When inserting an OPC UA Driver in an application in Elipse E3 Studio, this object's View is opened, according to the next figure.
OPC UA Driver's View
The available options on this View are described on the next table.
Available options for OPC UA Driver's View
Option
Description
Add Add
Adds a new OPC UA Subscription to an OPC UA Driver, an OPC UA Tag, OPC UA Block, or OPC UA Folder to an OPC UA Subscription, or an OPC UA Block Element to an OPC UA Block
Delete Delete
Deletes the selected item from this View
Select Server Select Server
Selects an OPC UA Server
Activate Activate Communication or Deactivate Deactivate Communication Communication
Activates or deactivates communication with the selected OPC UA Server. The activation option is only available if the EndpointURL property is configured
Import Tags Import Tags
Imports Tags to this OPC UA Driver
Information About Server Information About Server
Displays a window with information about the selected OPC UA Server
Tag Counting Tag Counting
Displays the total number of OPC UA Tags in this OPC UA Driver
Update IDs for All Tags Update IDs for All Tags
Updates the OPC UA Node Identifiers (NodeIDs) of all imported OPC UA Tags
NOTE
The Activate Communication Activate Communication option implies in a sufficient number of licenses for all OPC UA Tags and OPC UA Block Elements available in an OPC UA Driver. If there is no sufficient licenses for all OPC UA Block Elements of an OPC UA Block, the whole OPC UA Block does not communicate. Please check topic Licenses for more information about this behavior.
Some properties of an OPC UA Driver can be configured using Properties List, without creating scripts for this. To configure a property, locate it on Properties List and perform the required adjustments. For more information, please check Elipse E3 Reference and Scripts Manual.
