OPC UA Server Tab
OPC UA Server Tab
Allows configuring an OPC UA Server.
NOTE
An OPC UA Server is only available on 64-bit versions of Elipse E3.
OPC UA Server tab
OPC UA Server tab
Available option on the OPC UA Server tab
Option
Description
Enable OPC UA server
Enables or disables the OPC UA Server
Default option for OPC UA server object exposure
Defines how ElipseX objects are exposed through the OPC UA Server. Possible values for this option are eeExpose: Exposes ElipseX objects for reading and writing, eeExposeAsReadOnly: Exposes ElipseX objects only for reading (default), or eeDontExpose: Does not expose ElipseX objects
Connection point port
Number of the TCP/IP port for OPC UA Clients to connect to the OPC UA Server. The default value of this option is 48010
URL for OPC UA clients connection
Shows an example of a URL used by OPC UA Clients to connect to the OPC UA Server
Connection Points Security
Allows selecting one or more security policies to connect to the OPC UA Server. By default, the options Basic256Sha256, Aes128Sha256RsaOaep, and Aes256Sha256RsaPss are selected. For each one of these security policies, the security modes Sign (default), SignAndEncrypt, or Sign + SignAndEncrypt are available. The security policies Basic256 and Basic128Rsa15 were deprecated and must not be used, they are kept for compatibility reasons. Selecting the None option allows any OPC UA Server to connect to the OPC UA Server, without restrictions
Certificates
List with all certificates available for the OPC UA Server
Open Certificates Folder
Opens the folder on Windows Explorer where all certificates used by the OPC UA Server are stored
Refresh
Updates the Certificates list
