TrendAnalysis |
•Implemented a correction to prevent a TrendAnalysis' data source to send more data than needed to perform a drawing. This bug occurred since v6.0.91.
•Displays do not show anymore the value "-(nan)ind" for average, maximum, and minimum values in case there is no points. This bug occurred since v6.1.80.
•Points generated by interpolation are no longer considered for calculating average, maximum, and minimum values of a Pen. This bug occurred since v6.0.197.
•Implemented a correction in the update of data and drawing of a Pen when the source is asynchronous and with a lot of historical data. This bug occurred since v6.0.197.
•Columns persisted on a Display, saved in a language, and then opened in an E3 with a different language are no longer displayed. This bug occurred since v6.0.187.
•Removed the Include Begin and End Period option from the Export to CSV window. This bug occurred since v6.0.197.
•The manager of Automatic Pens must route remote Tags to their respective Domain. This bug occurred since v6.0.197.
