Interface |
•There are several new improvements in E3's interface for version 3.2. First, all icons were reviewed and updated, which makes its interface clearer, with 24-bit colors. In addition, windows' alignment and internal spacing now follow Microsoft's standards.
New Icons
•Properties Window's Links tab and Links Edition window now have new icons to identify link type, which makes the task of creating links more intuitive.
Icons
•In E3 Studio, all read-only cells have a slightly darker background. This makes it easier for users to identify which columns or properties are not enabled for editing.
•A new shortcut (F2) was created to edit a DrawString text selected on screen. This shortcut also works for objects with Caption or Value properties; in such cases, editing is performed on Properties List.
•On Properties List, there is a new icon for properties containing a file path to an image (for example, Screen.PictureFile and DrawPicture.FileName). Unlike previous versions, this icon clearly describes an image, not a text.
