TimeoutCall |
Read-and-write property specifying a time limit for a call to an OPC UA server, in milliseconds. This property cannot be changed while communication is active, its value must be greater than 0 (zero), and its default value is 10,000 (10 seconds).
NOTE |
In OPC UA standard, several calls allow to continue communication, with multiple responses from the server. So, this time ends up being the limit time for a response from an OPC UA server. |
