CurrentSubConditionName |
Determines the name of the last active Alarm condition. This is a read-only property. Available options for this property are described on the next table.
Available options for CurrentSubConditionName
OPTION |
DESCRIPTION |
LOLO |
Analog Alarm on a Very Low range |
LO |
Analog Alarm on a Low range |
HI |
Analog Alarm on a High range |
HIHI |
Analog Alarm on a Very High range |
DB |
Dead Band Alarm |
ROC |
Rate Of Change Alarm |
DIG |
Digital Alarm |
Default value of this property is an empty String.
NOTE |
For Discrete-type Alarm Sources, this property assumes the name of the user-defined Subcondition, on the Discrete tab of properties of this type of Alarm. |
