Configure a REC's TCP/IP Port |
Users can configure a port number used by REC, by using the REC TCP/IP port item.
If this item is not modified, the system automatically assumes the default port as 6515.
If this item is modified, the configured value indicates a port number used by the REC protocol. Values greater than 1024 and up to 65535 can be used. Values equal to or lower than 1024 are reserved. Null or invalid values enable using port 6515.
