Toolbars |
E3's Toolbar contains options that allow executing certain tasks quickly without using menus, such as opening Organizer. The next table shows all available options for E3 Studio's Default toolbar.
Available options for the Default toolbar
Option |
Description |
New |
Creates a new project (CTRL + N) |
Open Project |
Opens an existing project (CTRL + O) |
Save |
Saves a project (CTRL + S) |
Save All |
Saves the whole Domain (CTRL + SHIFT + S) |
Register Libraries |
Registers all loaded libraries (CTRL + SHIFT + L) |
Cut |
Removes the selected information and transfers it to the Clipboard (SHIFT + DELETE) |
Copy |
Copies the selected information and transfers it to the Clipboard (CTRL + C) |
Paste |
Pastes the selected information from the Clipboard (CTRL + V) |
Undo |
Undoes the last action executed (ALT + BACKSPACE) |
Redo |
Redoes the last action executed by the Undo option (CTRL + Y) |
Organizer |
Shows or hides the Organizer (CTRL + SHIFT + O) |
Gallery |
Shows or hides the Gallery (CTRL + SHIFT + G) |
Property List |
Shows or hides the Property List (CTRL + SHIFT + P) |
Domain Verifier |
Verifies errors in a Domain (CTRL + SHIFT + V) |
Show in Editor |
Shows an object in the object's View, if it is selected in Organizer (ENTER) |
Show in Organizer |
Shows an object in Organizer, if it is selected in the object's View |
Saves and Runs the Domain |
Saves all settings of projects and libraries, executes a Domain, and then executes an E3 Viewer (F9) |
Executes or stops the execution of the current Domain (SHIFT + F9) |
Refresh Domain |
Updates the current Domain (F5) |
Runs or Stops E3 Viewer |
Executes or stops the execution of the current E3 Viewer (CTRL + F9) |
Defragment Files |
Defragments the specified file |
Create Library Package |
Creates a compressed file with the available libraries in the Domain |
Find |
Searches for all occurrences of a given text in the whole Domain (CTRL + SHIFT + F) |
Replace |
Replaces all occurrences of a given text in the whole Domain (CTRL + SHIFT + H) |
Domain's Object Counting |
Displays a window with the amount of objects available in a Domain, separated by classes sorted alphabetically or grouped by modules (CTRL + SHIFT + C) |
Script Documentation |
Generates a documentation for scripts |
Version Report |
Shows project and library versions |
WatchWindow |
Shows or edits Tag and property values in E3 Studio, at run time (CTRL + SHIFT + W) |
