E3 Viewer Installation |
1.Execute the file e3viewer-x86-enu.exe.
2.Follow the on-screen instructions, and wait for the end of the installation.
3.An Installation Complete message appears when installation is successful. A program group named Elipse Software is then created on Windows Start menu.
A protection device is not needed for E3 Viewer installation.
NOTES |
•E3 Viewer's installer supports the /NOACP command prompt option, which ignores the installation of ActiveX Control Pad from MS Forms. This option must only be used if application screens do not use MS Forms components. •Some applications, such as MS Office, install ActiveX Control Pad during their installation process. |
