Time
Time
1.On the upper corner of SynopticScreen, insert a Display object.
2.Open the Display's Properties window and select the Format tab. Define its format as Time and, on the Type option, select the 13:06:03 item. This format displays hours, minutes, and seconds.
3.Select the Links tab. In the Value property, search on Source column, using AppBrowser, for the Demo Tag CurrentTime (on Server - Data). On the right, select the Value property and click Copy. Information goes from Tag to Display, therefore this is a Simple-type Link, that is, from property to source.
Link with CurrentTime Tag
