Print Chart Report |
Before exporting a Report, there is a possibility of viewing its appearance when printed.
1.On the ChartScreen, insert a Command Button labeled "Print".
2.Create a script on the Click event that uses a Print Report Pick. Select the ChartReport item in the Print report field and select the Screen item in the Output option.
Print Report-type Pick
