Rules for Naming Tags |
When specifying a name for Tags, please consider the following restrictions on characters, which are automatically replaced by an underscore character (_):
•Any character with an ASCII code less than 32 and the character with ASCII code 127 (DEL)
•Brackets ([ and ]), when used in expressions
•Backslash (\), which is used on resource paths
•Colon (:), which is used on Remote Domain and database paths
•Quotation marks ("), which are used to delimit Strings in expressions
•Question mark (?), which is used to delimit options in the SplitLink property and in ShowScreen and OpenScreen methods of a Splitter, in addition to a Screen's OnPreShow event
Check the next topic for more information about the way to reference objects by script or in Links.
