<< Click to Display Table of Contents >> Memories |
Simulator expects 30 digital registers (Coils) and 20 analog registers (Registers). Writing values is allowed directly to Simulator, by using the Value column of respective grids, when variation of values for a PLC is turned off.
With the Random Values option selected, random values are generated to all memories at every two seconds, as defined in the Interval field. The address of each PLC is always 1 (Device ID).
