Analog |
1.Insert a new folder named "Analog".
2.On Analog folder, create the following Tags:
•Address 1: Temperature_T1
•Address 2: Temperature_T2
•Address 3: Level_T1
•Address 4: Level_T2
3.Configure their N parameters according to the following information:
•N1: 1 (PLC address)
•N2: 1 (Operation code, or Register)
•N3: 0 (Additional parameter)
•N4: 1 to 4 (Register address)
4.Right-click this Driver and select the Activate Communication item to test these settings or click Activate or Deactivate Communication . In case these settings are correct, this Tag's row must be displayed in blue.
