<< Click to Display Table of Contents >> Exercises |
In these exercises, let's work with an XObject-XControl structure and create a third library object, an XControl ConfigPump, for the indexed Screen.
1.Create a new project and, using the Application Wizard, select the E3 Object Library option. Name this library as "WasteWaterLib". Click Next, add it to the active Domain, and finish.
