<< Click to Display Table of Contents >> E2Controls |
•Fixed a GPF that occurred when E2Text's Value property was changed and the object had no configured default Zone. This bug occurred since v3.0.219.
•E2Text's Zones properties tab is now updated correctly when another object is selected. This bug occurred since v3.0.219.
•E2Text's properties tab now correctly updates the Tip text box when a new Zone is selected. This bug occurred since v3.0.219.
•Fixed Zone samples on E2Text's properties tab, which presented problems due to lack of a background update. This bug occurred since v3.0.219.
•E2Control's properties tab are now translated to Portuguese in E3's Portuguese version. This bug occurred since v3.0.219.
•Fixed Delete button's behavior on E2Animation's Zone tabs (previously, the button did not work). This bug occurred since v3.0.219.
•Fixed a Toggle-type E2Button's bug, which kept alternating its value if the space button remained pressed. This bug occurred since v3.0.219.
•E2Text's Value property is now saved alongside the object's configuration; property type has been changed from Variant to Double. This bug occurred since v3.0.219.
•Fixed behavior of E3 Studio's properties list, which did not open a window for file selection when E2Bitmap's Filename property's button was clicked. This bug occurred since v3.0.219.
•Fixed several bugs on E2Text's Zones tabs.
•Fixed E2Animation's Border property behavior, which did not draw the border when set to True. This bug occurred since v3.0.219.
•E3 Studio's properties list now allows to configure E2Button's Bitmap0 and Bitmap1 properties when clicking the button. This bug occurred since v3.0.219.
•Fixed an incompatibility of E2Animation's and E2Button's redraw, which shrunk or stretched the image, unlike Elipse SCADA, which always kept the image's original size by cutting it or filling it with the background color. This bug occurred since v3.0.219.
•Changed the name of E2Animation's Zone edition tab from E2Animation to Zones. This bug occurred since v3.0.219.
•Fixed E2Text's and E2Animation's drawing, which did not fill the object's background when there was no active Zone in the current value. This bug occurred since v3.0.219.
•Reviewed E2Controls' properties descriptions, which were incomplete in AppBrowser. This bug occurred since v3.0.219.
•Fixed the behavior of E2Setpoint's and E2Display's Multiline property, which now can only be turned on when the object is set as String or Date types. This bug occurred since v3.0.119.
•Fixed E2Setpoint's line break when Multiline is enabled, which did not break any words larger than the control's length. This bug occurred since v3.0.119.
•When a value of a type other then the one set in E2Setpoint is attributed via scripts, E2Setpoint now accepts a value from the original type, but displays the formatted value according to Setpoint type. If conversion fails, the Setpoint is left empty. This bug occurred since v3.0.119.
•Fixed E2Setpoint's behavior of showing the keyboard's cursor at an incorrect place when Multiline property is enabled, and had more than one line of text. This bug occurred since v3.0.119.
•E2Bitmap now correctly displays an "X" when an image path is invalid or empty. This bug occurred since v3.0.219.
•Fixed redraw bugs in buttons for choosing colors on E2Text's Zones tab. This bug occurred since v3.0.219.
•Added a new button to select an image file on E2Animation's Zones tab.
•E2Text's and E2Animation's BlinkTime property can now be changed at run time. This bug occurred since v3.0.119.
•Fixed behavior of E2Text's and E2Animation's Zones tab. Now Min, Max, and Blink options are disabled when Zone is the default one. This bug occurred since v3.0.119.
•Improved image opening time in E2Controls, especially images with no transparency. This bug occurred since v3.0.119.
•Changed enumeration names on E2Button's Type property to English. This bug occurred since v3.0.119.
•Fixed E2Gauge drawing; ticks' texts are now centered according to them. This bug occurred since v3.0.119.
•E2Controls now have two different versions, English and Portuguese (other versions use the English version). This bug occurred since v3.0.219.
