<< Click to Display Table of Contents >> Session Information |
This section contains information about the properties of a Session Information (SessionNodeBase) object. This object does not contain events nor methods associated to it.
NOTE |
Using brackets when referencing this object in scripts, such as "[?Server].Clients.RemoteDomains", is mandatory. |
The currently available Session Information objects are the following:
•RemoteDomains: Remote Domain connections
•Studios: E3 Studio connections
•Viewers: E3 Viewer connections
